Vecchio 05 febbraio 09, 00:17   #2 (permalink)  Top
cecco
Adv Moderator
L'avatar di cecco
Data registr.: 11-04-2006
Forse!
A lightweight speed controller for 400-size and standard 480-class motors.
• BEC receiver power supply (up to 10 cells - jumper used to select with / without separate receiver battery)
• Low-voltage cut-off with automatic Number of cells matching
• Power-on guard
• Overload and excess voltage protection
• 6-8 NiCd/NiMH
• 2 Li-BATT cells
• Automatic low-voltage cut-off for Li-BATT, NiCd and NiMH
• EMF-brake
Specification:
Number of cells: 6 ... 8, 2 Li-BATT
Pulse width: 1250 - 1750 μsec.
Max. continuous current (5 min.): 16 A
BEC voltage: 5 V
BEC current: max. 1 A
BEC dissipated power: max. 2.5 W
Pulse frequency: 6000 Hz
Dimensions (L x W x H) approx.: 27 x 20 x 8 mm
Connections
Motor: bare wires
Battery: bare wires
Dicono che sopporta fino a otto celle NiXX (9,6V) escludendo il BEC ma lo danno per un massimo di due LiPo ......magari per un pò regge ma quando poi decide di mollarti è....... per sempre.....
Lassa perdé.
Francesco
