Discussione: motore aiuto
Vecchio 18 ottobre 05, 22:56   #3 (permalink)  Top
Peppe46
L'avatar di Peppe46
Data registr.: 03-10-2004
Residenza: Pesaro (PU)
Originally posted by Danilo@18 ottobre 2005, 21:27
Cari amici con questo motore riesco a spingere un aeromodello dal peso di 700gr?
Specifications:
RC Smart X-SPEED Outrunner Brushless Motor 1280
>Rpm(Kv): 1280Rpm/V
>Max Currect: 25A
>Max Eff: 90%
>Recommended Rotor Blade: 10x6 to 11x7 or 8.5x5 to 10x5
>Weight: 58g (Motor only)
>Total Length: 47.9mm (Motor only)
>Motor Body Diameter: 28mm
>Shaft Diameter: 2.97mm(Front) & 6mm(Back)
>Shaft Length: 14.3mm
>Recommended Input Voltage: 6 - 18 Volt
Il regolatore posso alimentarlo con batterie lipo 3 celle?
Specifications:
RC Smart 30A Speed Controller
>Size: 62mm x 26mm x 8mm
>Weight: 33g each
>Constant Current: 30A
>Max Current: 40A
>Input Volt: 3V - 12V
>Low-Voltage Cutoff: Auto detect and set
Advantage of the RC Smart Speed Controller
-Low resistence
-High rate PWM
-Sixteen cells Max (with BEC disabled)
-User programmable brake
-Low voltage auto setting based on battery
-Throttle range self-adjusting
-Soft start ramp up
-Runs motor in forward or reverse
-Auto motor cutoff with reset
-Safe power arming program ensures motor will not run accidentally after turn on
-Low torque start
-Auto shut down when signal is lost
Con quel motore ne spingi anche 2 !!
Peppe46 non รจ collegato   Rispondi citando
