Vecchio 25 gennaio 09, 17:18   #3 (permalink)  Top
rillo75
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
First, the rx connections:
1. Right side elevator into ELEV channel
2. Left Side elevator into AUX 2 channel
3. Right Side aileron into AIL channel
4. Left side aileron into FLAP (AUX 1) channel
5. Rudder and Throttle into the normal channels
TX program
1. Go into the Set-up mode (hold down scroll and select keys while turning on tx)
2. Scroll to the Input Select screen
3. Set Aux2 to INH, AUX2 TRIM to INH, FLAP to INH, FLAP TRIM to INH
This turns off both of these channels from the levers and switches. This is the proper way to do this, not using P-mixes or Travel adjust.
4. Scroll to Wing Type
5. Activate Flaperon
Elevator Set up
1. Power off tx and turn back on. Go to normal programming mode
2. Scroll to P-mix 6 (or Mix 5 - mix 5 and 6 "master" trim changes into both master and slave channel. Mixes 1 through 4 do NOT - editor). Set ELEV as master and AUX2 as slave.
3. Scroll to Sub Trim and set the neutral for the right side elevator with ELEV channel and the neutral for the left side elevator with AUX2.
4. Scroll to Travel Adjust. Set the desired travel for the right side elevator with the ELEV adjustment.
5. Scroll back to P-Mix 6 and tweak the travel of the left side elevator to match the right side with the mix values, for each stick direction.
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
rillo75 non รจ collegato   Rispondi citando
