Vecchio 13 gennaio 09, 17:37   #6 (permalink)  Top
f.alberto
L'avatar di f.alberto
Data registr.: 01-04-2006
Residenza: Vittoria RG
Originalmente inviato da lombardoa Visualizza messaggio
Sulle discussioni... ho trovato Ringo che spiega come si programma...ammesso che sia lo stesso...
Saluti..art
fine controller & programmable
Gues Ringo Very good controller, specially for this money.
With 8A it becomes a little bit warm, no problem.
One disadvantage: there is no manual included. (5 Stars with manual!)
With my controller there is no difference in break with the 10% throttle position reported by Frank. Are the different versions?
I have searched in web an i found that the controller is programmable.
Possible options:
- LIPO-mode (auto selection 2/3 cells)
- NIMH-mode
- Break on / off
To program this controller you have to move transmitter throttle to full position.
Now connect battery to controller.
Wait some seconds, than you hear:
*peep* - *short pause* - *peep*
*pause*
*peep*peep* - *short pause* -*peep*peep*
*pause*
*peep*peep*peep* - *short pause* -*peep*peep*peep*
*pause*
this sequence will repeat...
When you want to use NIHM cells, you have to move throttle to off position when you hear the first *beep*beep*. Than you have to wait for a longer *beeep* and a short *beep*. That's all. You can disconnect battery now.
When you want to select LIPO mode, start from the beginning (throttle full, connect battery, listen to the beeps)
At the time when you hear the first single *beep* move throttle to off and wait for
*beeep* and *beep*.
When you want to switch Brake On or Off, start from the beginning, then wait for the first *peep*peep*peep* within one sequence and put throttle to off. Wait for *beeep* and *beep*.
Note: When you connect battery and throttle is in off posit
Ti ringrazio per l'interessamento, per caso sai cosa indicano * nella programmazione?
f.alberto non รจ collegato   Rispondi citando
