Discussione: Avonds F-15
Vecchio 05 gennaio 09, 16:45   #4 (permalink)  Top
Hornet One
Guest
Messaggi: n/a
Originalmente inviato da FelixGiant Visualizza messaggio
Non considerando la spesa un problema...una DS-94 HDT + Lehner 2280/9 + Schulze 40.160H + 12 o 14s 5000 dovrebbe dare risultati ottimi sulla carta, ma poi quali i problemi pratici??
E-Motor Calculator for Ducted Fans:
* the prediction of the motor case temperature is critical (>80°C/180°F). Please check! * [1]
P.S. ovviamente la versione D/F che pesa meno, non quella super dettagliata per turbina!!!
Philip Avonds Scale Jets:
The airbrake on the F-15 not only looks nice, it can also be very helpfull during the approach to the landing. The high drag generated allows you to fly the approach at a higher throttle setting and this will make it easier to make accurate, scalelike landings, especially when operating from small fields.
Note: the airbrake can only be installed on Turbine F-15's (internal clearance issue with Ducted Fan) [2]
  Rispondi citando
