Salve.. volevo farvi vedere cosa ho scoperto per caso sul web:
Schubeler Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
Schubeler Jets - EDF
All ducted fans of the DS-XX-DIA HDT series come fully assembled, fine-balanced and quality-checked, you simply have to install your motor and the system is ready to fly.
Schubeler DS-26-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
300 USD
HDT = High Dynamic Thrust
The 65mm fan for highest dynamic thrust
The DS-26-DIA HDT is based on the DS-30-DIA HDT and is with 65mm diameter our smallest fan unit. Its aerodynamic characteristics are a perfect match for small and fast EDF jets. The rotor has only 3 blades which however have a big depth for an efficient airflow.
Unlike other ducted fans of this diameter class its short rotor unit runs very smoothly and does not even overload a thin 3.17 mm shaft with undesirable resonance vibrations. Like his "big brothers" the DS-26-DIA HDT is also fully made of carbon fibre.
Technical Data:
Diameter: 65mm
Fan swept area: 26cm²
Weight incl. Secure Fan Fix frame: 30g
Static thrust range: tbd
Max. motor diameter: 29,3mm
Speed range: 22.000 - 50.000U/min
Power input: tbd
Static efficiency: tbd
More measurements for this ducted fan can be found at fan measurements.
Schubeler DS-30-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
The 69mm fan for highest dynamic thrust 300 USD
Schubeler DS-44-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
365 USD
The 85mm fan for highest dynamic thrust
Like all Schubeler fans the DS-44-DIA HDT is "made in Paderborn" in all-carbon fibre design. You can rely on the combination of low weight and ultra-high strength! The limiting factor for maximum power input is the motor - not the ducted fan.
Schubeler DS-51-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
365USD
The 90mm fan for highest dynamic thrust
Schubeler DS-75-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
440 USD
The 110mm fan for highest dynamic thrust
The DS-75-DIA HDT is based on the larger DS-94-DIA HDT and constructed in the same way with its outer diameter being reduced to 110mm. The smaller DS-75-DIA HDT can be used in models of the former 7.5cm³ ducted fan class.
Schubeler DS-94-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now
440USD
The 120mm fan for highest dynamic thrust
With a fan swept area of 94cm² and a diameter of 120mm the DS-94-DIA HDT is currently our biggest and most powerful ducted fan. This fan can efficiently convert power inputs of up to 5.7KW into a very high thrust impulse - thus being an ideal alternative for turbines of the 80N-class.
Along with the design of its predecessor - the DS-94-DIA 3-ph - we developed the 8mm shaft system - by now an established and absolutely necessary size for handling the high motor powers in a 120mm fan unit. The optionally available Secure Fan Fix system now also provides the possibility to precisely and securely fix the ducted fan within the fuselage.
Like all our ducted fans the DS-94-DIA HDT is also produced in CAD-CAM molds, hand-laminated and assembled in Paderborn.
