Vecchio 26 agosto 08, 18:16   #3 (permalink)  Top
francolvr
Franco vola più in alto di tutti noi
L'avatar di francolvr
Data registr.: 15-05-2003
Originalmente inviato da bimoto Visualizza messaggio
so di certo che l'Hyperion NON fa scarica.
Ma chi te l'ha detta una IDIOZIA simile?
Leggi scorrendo le righe in rosso!
Hyperion EOS 1210i Charger
User’s Manual for 1210I-A with A123 Mode
Warnings:
The EOS 1210i is a carefully-designed charger with many built-in
safety features, such as reverse polarity protection, input voltage
error warning, and cell-count mismatch warnings for lithium
chemistry batteries. HOWEVER, IT IS THE RESPOSIBILITY OF THE
USER TO INSURE THAT THE CHARGER IS CONFIGURED AND USED IN
A SAFE MANNER IN PROPER ENVIRONMENT. Note that as cell count
of lithium batteries becomes higher, all warning systems become less
accurate. As such, we strongly recommend the use of Hyperion
LBA10 balancers when charging lithium batteries, and especially so at
4S or higher. LBA provide much additional safety, because the LBA
· Always be sure that the charger is properly configured for
the correct battery type.
· Be sure that the batteries you charge are capable of charge
at the rate you select.
· Never charge batteries unattended.
· Charge only in a fire-resistant environment, such as on
concrete or brick, rather than wood surfaces.
· Do not charge near easily flammable materials.
· Do not charge batteries inside a model.
· Charging outdoors is recommended whenever practical
· Use only high-quality gold 4mm bullet connectors for charge
output cable connection to the charger. See “setup”.
·Insulate all Output connectors to eliminate the possibility of
short circuit. Damage caused by output short circuit is not
covered by warranty.
· Do not drop or cause other shock to the charger, nor subject
it to moisture or water
· Do not attempt to charge battery packs made from different
types of cells, a mixture of old and new cells, or cells made
with chemistry not supported by the EOS 1210i
· Do not attempt to charge “non-rechargeable” dry cells.
· Do not open the case of the charger under any
circumstances. Doing so will void the warranty.
· Keep the charger away from children or pets at all times.
In the event of injury of any kind, seek the attention of
medical professionals immediately.
Specifications:
· 2-Line, 16-Char, Blue Backlit LCD Data Display
· 10 User-def inable Memory Posit ions
· Charge/Discharge 1 to 12 cells Lithium Bat teries (3.7V/cell nominal types)
· Charge/Discharge 1 to 12 A123 Brand cells(3.3V/cell nominal types)
·Charge/Discharge/Cycle 1-30 cell NiCd/Ni-MH
· Charge/Discharge 2-12v Lead Acid Bat teries
· Balancer Safe - 55V max out on open circuit
· DataPort for Hyperion LBA10 Balancers
· 0.1A -10.0A Charge Current (180 Wat t Maximum)
·0.1A - 5.0A Discharge Current (50 Watt Maximum)
· TCS - Lithium Terminal Capacity Selection
50%~100%
· Rich Data Displays during and after charging and
discharging
· Input Cable with 4mm Connectors and Clamps
· Output Cable Set Included, with 4mm Connectors
· Integral, Thermostat-Controlled Cooling Fan
Ultima modifica di francolvr : 26 agosto 08 alle ore 18:24
francolvr non è collegato   Rispondi citando
