Discussione: La Royal Pro è uscita
Vecchio 22 agosto 08, 18:24   #15 (permalink)  Top
CantZ506
L'avatar di CantZ506
Data registr.: 10-04-2004
Residenza: Brescia
Ho scritto a Multiplex per avere informazioni sull'upgrade del software e su centri assistenza in Italia. Forse può interessare ai possessori della EVO:
Dear Sirs,
I've read somewhere that the new EVO PRO is already available and I wonder if also upgrading of existing EVO is already possible too.
I've few more questions:
1. Is upgrading of the (synth) tx module necessary to obtain PCM modulation only, or is it necessary also for other reasons?
2. If the answer to the above question is "for PCM only", which I'm not interested in, could I introduce all other changes ?
3. Should I sent my EVO to your factory for upgrading, or is there in Italy any service center where I can send to?
I knew that firm Holzner & Premer in Tisens (Sued Tirol) could do the job, but I'm not sure if they handle EVOs radios any more.
Many thanks and best regards,
Ecco la risposta:
Dear Sir,
1. upgrading of the Tx module is only necessary if you want to use M PCM receivers.
2. You can.
3. You have to send the radio to our factory in Germany. But you have to wait some more weeks. The update is not available yet. You will find an information on our homepage if it is available.
Kind regards
Helmut Heid
After Sales Service
MULTIPLEX Modellsport GmbH & Co. KG
commercial register: Mannheim HRA 503805
CEO: Chun Sue Park, Dieter Wörner
tax-number: 30042/14456
WEEE reg nr: DE 89838279
Übermittlungsdatum: 22nd August, 2008 Friday 14:21:13 GMT +0100
Betreff/Subject: Royal EVO's software upgrading.
versand durch cantz506@xxxxx.xxx (Ticketeigentümer)
Per i non anglofoni:
1. La modifica al modulo tx serve solo se si vuole trasmettere anche in PCM
2. Se non si è interessati al PCM, si possono comunque avere tutte le altre modifiche.
3. Bisogna inviare la radio in ditta in Germania, quando la modifica sarà disponibile. Ci sarà la notizia sul sito MPX.
Ciao, Piero.
