Originalmente inviato da tonnuns Riscrivo le caratteristiche indicando anche le eliche consigliate e il peso:
Rotational Speed 1200 RPM/V
Continuous Current 25A
Max. Current 30A
Input Voltage 6 - 22V
Max. Efficiency 98%
No Load Current 0.7A
Internal Resistance 78mΩ
Motor Dimensions (Diameter x Length) 28.2mm x 28.8mm
Shaft Dimensions (Diameter x Length) 2.97mm x 13mm
Input Battery Types NiCd/ Nimh/ Li-po Battery
Recommend Model Airplane
Recommended Rotor Blade: 6 x 4 to 11 x 6
-Net Weight: 52g (Motor only)
O meglio questo:
Rotational Speed 1280 RPM/V
Continuous Current 20A
Max. Current 25A
Max. Efficiency 95%
No Load Current 0.8A
Internal Resistance 55mΩ
Motor Dimensions (Diameter x Length) 28.2mm x 31.9mm
Shaft Dimensions (Diameter x Length) 2.97mm x 12.5mm
Recommended Rotor Blade: 10x6 to 11x7 or 8.5x5 to 10x5
-Net Weight: 55g (Motor only) | Mi pare stiano dando i numeri!
__________________ Ciao, Piero.
