annuncio
Comprimi
Ancora nessun annuncio.
Soluzione completa..... quale?
Comprimi
X
  • Filtro
  • Ora
  • Visualizza
Elimina tutto
nuovi messaggi
  • Soluzione completa..... quale?
    Che voi sappiate, oltre a MK esiste un'altra soluzione completa che supporti GPS HOLD e RTH?
    Da ricerche fatte, a parte il lavoro di Redfox74 non ne ho viste altre.
    Ciao.
    SDModel -> Eliche controrotanti, motori, ESC, frame.....
    MultiWii Italia
  • #2
    Originariamente inviato da stefanoxjx Visualizza il messaggio
    Ciao.
    UAVX uavp-mods - UAVX: A collection of modifications and experiments inspired by the original UAVP quadrocopter. - Google Project Hosting
    UAVX Functionality
    UAVX has the following functionality:
    Full autonomous navigation with 3D (altitude and position) acquisition, auto-takeoff and landing. 4D functionality (time) may be activated later.
    Failsafe and selectable return to home with selectable auto-land and motor shutdown.
    Ultrasonic rangefinder support for precision low-hover and landing.
    Quadrocopter, Tricopter, Octocopter, Hexacopter, Helicopter and some fixed wing aircraft.
    PWM and I2C ESCs supported.
    Support for a wide range of Tx/Rx combinations and custom configuration capability for new combinations.
    Flight simulation mode for mission planning and verification.
    Comprehensive flight telemetry including raw GPS, byte stuffed binary, and text compatible hand-held ground-stations including those developed by contributors to this thread.
    UAVX is supported by:
    UAVXNav: A mission planner with integrated ground-station for use in flight.
    UAVXGS: A ground-station which displays a much larger set of internal UAVX variables including sensor values whilst in flight.
    UAVPSet: For setting UAVX control parameters and sensor testing.
    Quadricottero News
    http://www.facebook.com/Quadricottero
    Commenta
    • #3
      Ciao.
      mi viene in mente microdrone
      microdrones - your eye in the sky
      Commenta
      • #4
        XAircraft X650 con compass e GPS
        Commenta
        • #5
          Confermo Xaircraft x650 con compass e gps , ne sono possessore e non posso che essere soddisfatto!
          No! provare no! Fare o non fare , non c'è provare!
          Commenta
          • #6
            Scusate, non ho specificato, chiedevo su soluzioni opensource.
            Quella indicata da Danveal mi sembra molto interessante.
            Grazie.
            MultiWii Italia
            Commenta
            • #7
              Grazie.
              Prego, stanno anche facendo il porting su ARM, UAVXArm
              Quadricottero News
              Commenta
              • #8
                Originariamente inviato da danveal Visualizza il messaggio
                Grazie a te
                MultiWii Italia
                Commenta
                • #9
                  Se può interessare sto collaborando con F. Varesano, il creatore di freeimu per fare una scheda basata su arm con sensori ( baro acc gyro magn ) ed esc inclusi. Per ora sono in fase progettuale dell'hardware chiamato ICARUS, cmq sarà un progetto interamente opensource, con lo scopo di avere una interfaccia completa e pratica.
                  Credo che inizialmente ci sarà una versione per quad, successivamente magari farò i pcb per gli opto e gli esa. Vorrei progettare il circuito stampato in modo che collegandoci una batteria e mettendoci 4 piccoli motori direttamente su di esso gia voli, cosi da potere fare senza frame mini quadricotterini, e comuque avrà a bordo esc da 30 ampere che permetteranno di pilotare quad piu grossi. Se qualcuno vorrà contribuire con consigli, aiuti ecc benvenuto. Presto faremo il sito.
                  Commenta
                  • #10
                    Originariamente inviato da blark Visualizza il messaggio
                    Ottima notizia.
                    Tienici informati sugli sviluppi del progetto
                    MultiWii Italia
                    Commenta
                    • #11
                      Arducopter.
                      arducopter - Arduino-based autopilot for mulitrotor craft, from quadcopters to traditional helis - Google Project Hosting
                      Completamente open source.
                      Le ultime novità sono il supporto MavLink oltre che a GPS hold RTL etc. puoi anche pilotarlo dal PC programmando le missioni o più semplicemente mandando i comandi via wieless.
                      Secondo me le potenzialità sono ottime anche se ancora in beta.
                      Oltre a ciò RedFox sta facendo il porting del codice per essere utilizzato su ARM
                      Multipilot32 - FOXTEAM UAV CLAN
                      Emile
                      Commenta
                      • #12
                        Originariamente inviato da emile.c Visualizza il messaggio
                        Emile
                        Ordinato proprio ieri sera un kit completo a Roberto
                        MultiWii Italia
                        Commenta
                        • #13
                          azz....io l'ho ordinata stamattina..
                          Forza Foxteam!!
                          Commenta
                          • #14
                            Originariamente inviato da Claudiopapi Visualizza il messaggio
                            Forza Foxteam!!
                            Bene, così potremo darci una mano a vicenda
                            MultiWii Italia
                            Commenta
                            • #15
                              Già, ne ho presa una anche io. Solo che la utilizzerò con la Oilpan di DIYdrones.
                              Vediamo un po', mi sa che dobbiamo dargli una mano a fare un tutorial un po' più chiaro...
                              E.
                              Commenta
                              Sto operando...
                              X
