Mikado #04890 Current/Voltage/Capacity Sensor VBar Control Mikado #04890 Current/Voltage/Capacity Sensor VBar Control Hardware Features of the Current/Voltage/Capacity Sensor for flight packs * Individually precision calibrated * Optocoupler * Reverse battery protection * No influence from motor or current carrying wires Software Features * Direct displaying from voltage and capacity * Max. current and min. voltage storage * Logfile data from the flight * Battery Logbook with names * Adjustable capacity, residual capacity and voltage for each battery * Residual capacity is shown as bar in the radio display * Overdischarge Warning * Warning at use of not fully charged batteries * Loud speaker announcement for reducing battery capacity Notes * Requires a VBar with Spektrum Satellite connectors (telemetry bus for VBar Control) * Not suitable for measuring receiver packs only (e.g. on a nitro heli) * extracted capacities are not added up, measurement only on a per-flight basis Specifications Current Consumption2.5 mAWorking Temperature Range-5 to 50 °C, 23 to 122 °FDimensionsapprox. 20 x 20 x 10 mmPower Rating120 A continuous, 330 A peakEffective Range (current)0.1 A to 300 AEffective Range (voltage)5 V to 100 V (2s to 16s LiPo)Resolution0.01 A / 0.01 VContents DeviceVoltage/Current Sensor with connecting wires to battery and ESCConnecting WireSensor wire 500 mm USATO, OTTIME CONDIZIONI PEZZO: 35€ Spedizione: 10€ Italia, 20€ Europa. --------------------------- Nome: Diego Cognome: Torazza Città: Genova |
Venduto! |
| Tutti gli orari sono GMT +2. Adesso sono le 12:55. |
