Motore Turnigy g110 e regolatore 100A 4 Allegato/i Ciao a tutti vendo: MOTORE TURNIGY G110 - motore Turnigy G110, intonso praticamente nuovo, equivalente al Glow 110 Prezzo poco trattabile 50. Caratteristiche: Spec. Battery: 8~9S Cell /29.6~33.3V RPM: 295kv Max current: 55A No load current: 10V/1.2A Current capacity: 65A/15sec Internal resistance: 0.03 ohm Weight: 485g (not including connectors) Diameter of shaft: 8mm Dimensions: 79x63mm Required; 85A HV ESC 8S~9S Li-Po / 24 ~ 32-cell Ni-MH/Ni-Cd 17x8 ~ 19x10 prop --------------------------------------------------------------------- REGOLATORE Turnigy 100A, usato pochissimo, come da foto in ottime condizioni a 60 trattabile. Caratteristiche Spark suppressor RPM sensor Brake modes Super soft, soft and normal start modes Low voltage protection Max burst current 120A LiPo, Li-ion, NiMh and Nicd compatible Large mounting plate Separate program wire (for use with program card) Extreme low resistance PCB used Military standard capacitors used to decrease RF noise/interference Configurable throttle range (compatible with all transmitters) Specs: Cont. Current: 100A Burst Current: 110A BEC Mode: N/A (no BEC) Lipo Cells: 5-12 NiMH : 15-36 Weight: 125g Size: 60x60x11mm CPU Clock Speed: 12Mhz Max Speed: 210,000 RPM (2 pole motor), 70,000 RPM (6 pole motor), 35,000 RPM (12 pole motor) --------------------------- Nome: Gianni Cognome: Stragapede Città: Milano - Busto Arsizio - Legnano |
| Tutti gli orari sono GMT +2. Adesso sono le 19:00. |
