166g, lighter than iPhone 6 Plus
The G3s Aluminum alloy construction is strong but extremely light, only 166 g and allows the aircraft to fly longer.
Excellent stability performance
The G3 comes with 3 sets of shock ball vibration dampeners to support various airframes.
The three-axis stability far exceeds two-axis and ensures a stable and smooth flight even at high speed.
Easy use
Easy installation, just set up, power-and-go.
No need to remove camera when charging or changing the SD card or to remove the camera battery.
Totally enclosed structure
The G3 has a totally-enclosed motor, so it can not be affected by iron filings, sand and dust.
The G3 is perfectly compatible with all kinds of aircraft. Suitable to GoPro ® 3+/GoPro ® 3 motion camera.
The G3 can be used with multi-rotors, fixed wing, helicopter and other aircraft.
Features:
3-axis gimbal
High precision control system
Effortless Setup
Independent IMU
Light-weight
Aluminum alloy body
Peripheral:
Supported Camera Gopro Hero3 , Gopro Hero3+, Gopro Hero4
GCU Input Power LiPo (3S~6S, 11.0V~26.0V)
Electrical:
Gimbal Operating Current:
Static current : 100mA (@7.4V)
Dynamic current : 300mA (@7.4V)
Gimbal Input Power LiPo (3S~6S, 11.0V~26.0V)
Operating Temperature 0°C ~60°C
Gimbal Weight 166g
Performance:
Controlled Angle Accuracy Tilt/Roll: ±0.05°; Yaw: ±0.05°
Maximum Controlled Rotation Speed Tilt axis : ±130°/s
Controlled Rotation Range Tilt axis control: -100 ~ +10°
__________________________________________________ ___________________ __________________________________________________ ___________________
JIYI G3 three-axis gimbal.-JIYI
sales@jiyiuav.com
+86 21-6113-9769
Facebaook: https://www.facebook.com/JIYIROBOTICS
Easy use
Features:
3-axis gimbal
Effortless Setup
Independent IMU
Light-weight
Aluminum alloy body
Peripheral:
Electrical:
Gimbal Weight 166g
Performance:
sales@jiyiuav.com
+86 21-6113-9769
Commenta
