annuncio
Comprimi
Ancora nessun annuncio.
(action cam) Nuova SJCAM 4000+ wifi
Comprimi
X
  • Filtro
  • Ora
  • Visualizza
Elimina tutto
nuovi messaggi
  • (action cam) Nuova SJCAM 4000+ wifi
    Aggioramento 27/07/15
    ecco qui la mia recensione della SJ4000+
    Nel mondo ormai affollatissimo e sempre pieno di novità, si rinnova anche la sj4000 con il nuovo modello SJ4000+ Wifi
    SJ4000+
    Ecco le principali caratteristiche:
    Specifications
    General
    Model: SJCAM SJ4000+ WiFi
    Type : Sports Camera
    Chipset Name: Novatek
    Chipset : Novatek 96660
    Special Function: Cycle recording, Microphone, HDMI output
    System Requirements: Win 7, Windows 2000 / XP / Vista
    Storage
    Max External Card Supported: TF 32G (not included)
    Class Rating Requirements: Class 6 or Above
    Display
    Screen Size: 1.5inch
    Screen Type: TFT
    Power
    Battery type: Removable
    Capacity : 3.7V 900mAh li-ion rechargeable battery
    Power Supply: DC 4.2V 450mA
    Charge Way : USB charge by PC
    Working time: 1080P up to 80minutes
    Primary Info.
    Wide Angle: 170 degree wide angle
    Image Sensor: OV4689 COMS
    Camera Pixel: 12.0MP
    Focus Range: 12cm~infinite
    Video/Image/Audio
    Video Format: MP4
    Video Resolution : 1080P (1920 x 1080), VGA (640 x 480), 720P (1280 x 720)
    Video System: PAL, NTSC
    Video Frame Rate: 120fps, 30fps, 60fps
    Video Output: HDMI
    Image Format : JPEG
    Image Resolution : 5M (2592 x 1944), 8M (3264 x 2448), 12M (4032 x 3024)
    Audio System: Built-in microphone/speacker (AAC)
    Exposure Compensation: +0.3, +2, -2, -0.3, 0
    White Balance Mode: Auto
    Functions
    Loop-cycle Recording : Yes
    HDMI Output: Yes
    Time Stamp: Yes
    Interface Type: HDMI, USB 2.0
    Language: Japanese, French, Korean, Portuguese, Spanish, Polski, Simplified Chinese, German, Italian, Traditional Chinese, Russian, English
    Dimension/Weight
    Product Weight: 0.063 kg
    Package Weight: 0.670 kg
    Product Size (L x W x H): 5.9 x 4.1 x 3.0 cm / 2.32 x 1.61 x 1.18 inches
    Package Size (L x W x H): 20.0 x 12.0 x 9.0 cm / 7.86 x 4.72 x 3.54 inches
    Package Contents
    Package Contents: 1 x SJCAM SJ4000+ WiFi Sports DV, 2 x Base, 1 x Fixed Base, 3 x Switch Support, 1 x Bicycle Support, 2 x Bandage, 2 x 3M Sticker, 1 x USB Cable, 1 x Wiper, 1 x Adaptor, 1 x Clip, 1 x Helmet Mount, 1 x Backup Back Cover of Waterproof Case, 1 x English User Manual
    Monta un nuovo processore e sensore capace di riprese a 2k
    Ciaoooo
    Ultima modifica di il_Zott; 24 luglio 15, 21:05.
  • #2
    Ciao,
    Ho visto che SJCAM SJ4000 Plus e' in promozione
    SJCAM SJ4000 Plus WiFi Standard Version Sports DV 1.5 inch 170 Degree Wide Angle Novatek 96660 Outdoor Camera Camcorder-149.00 and Free Shipping| GearBest.com
    Adesso regala la scheda di menoria (32G)
    Commenta
    • #3
      Sj Cam
      Ciao a tutti,
      sono un felice possessore di SJ CAM 4000 wifi,
      Mai un problema e svolge la sua funzione molto egregiamente,certo,la Hero4 è un'altra cosa,ma il rapporto qualita'-prezzo è ineguagliabile,almeno credo.
      Di certo,la consiglio
      Commenta
      • #4
        Originariamente inviato da skitzato Visualizza il messaggio
        Ciao a tutti,
        Ma hai letto il titolo ? ;) sj4000 +
        C'è il + e questo indica un modello nuovo, che con la sj4000 non ha più nulla.
        Inviato dal mio iPad utilizzando Tapatalk
        Commenta
        • #5
          La sj5000+ in teoria,dovrebbe restare ancora superiore a questa nuova 4000+?
          Commenta
          • #6
            Boh... In realtà non saprei, i sensori sono differenti come i processori, bisogna vedere come li hanno usati e ottimizzati, per esempio la xiaomi yi doveva essere un bomba, ma in realtà non é tutta questa cam, per gli stessi €€ c'è di molto meglio. La 5000+ ha un sensore da 16mpix e fa foto molto belle, bisogna vedere questa che fa... Alla fine i mpx non é che contano molto, 12/16mpix sono sempre un bel po', speriamo che siano stati usati bene.
            Sarà ma con queste cam io uso più le foto che i video ;) ed la funziona time lapse la trovo veramente comodissima.
            Se riuscirò a testale vi dirò come va, col solito confronto, anche con la 5000+ ;).
            Ciaooo
            Commenta
            • #7
              Grazie 1000 per le tue recensioni il Zott..
              Avendo una certa "fretta",forse mi conviene buttarmi direttamente sulla 5000+,almeno andrò sul "sicuro"..
              Commenta
              • #8
                Appena possibile eseguirò anche io una recensione della SJ4000+ con una comparazione video rispetto alla SJ4000 classic e la Xiaomi YI
                al momento la SJ4000+ potete acquistarla qui da Gearbest..
                Il mio canale YT iscriviti grazie
                Commenta
                • #9
                  Ho creato una pagina Facebook per raccogliere info e immagini... ;)
                  https://www.facebook.com/pages/Sj400...19893741628032
                  Commenta
                  • #10
                    premetto che possiedo la sj5000+ e la sj4000wifi, francamente questa sj4000+ non capisco che scopo abbia, gia la sjcam sta sfornando revisioni nuove ogni 3-4 mesi (vedi il caso della 5000+ con display da 1,5'' e quella nuova con display da 1.54'') a me pare che si facciano concorrenza da soli....
                    Gam-Gam-Gam Ki Elech, Be-Beghe Tzalmavet, Lo-Lo-Lo, Ira Ra, Ki Atta Immadì, Shivtechà umishantechà, Hema-Hema yenachamuni....
                    Commenta
                    • #11
                      credo che probabilmente la vecchia 4000 andrà presto in pensione..
                      Commenta
                      • #12
                        Originariamente inviato da Marcofan76 Visualizza il messaggio
                        dici? in teoria la serie 5k doveva già sostituire la 4k...
                        sarebbe da confrontare la 4k+ con la 5k+
                        Commenta
                        • #13
                          Cosa che forse farò 😜
                          Commenta
                          • #14
                            Originariamente inviato da il_Zott Visualizza il messaggio
                            scusa ce l'hai già la 4k+ ?
                            in caso mi sapresti dare le dimensioni esatte? perché la 5k+ ha qualche mm in più rispetto alla 4k e a differenza di questa non entra perfettamente in alcuni gimbal come il walkera g-2d
                            Commenta
                            • #15
                              Ancora no..
                              Commenta
                              Sto operando...
                              X
