annuncio
Comprimi
Ancora nessun annuncio.
3DR Pixhawks
Comprimi
X
  • Filtro
  • Ora
  • Visualizza
Elimina tutto
nuovi messaggi
  • 3DR Pixhawks
    3DR Pixhawks
    Key Features
    • -Sistema operativo NuttX RTOS
    • -32 bit STM32F427 Cortex M4 core with FPU 168 MHz/256 KB RAM/2 MB Flash
    • -32 bit STM32F103 failsafe co-processor
    • -14 PWM / Servo outputs (8 with failsafe and manual override, 6 auxiliary,
      high-power compatible)
    • - Abundant connectivity options for additional peripherals (UART, I2C, CAN)
    • - Integrated backup system for in-flight recovery and manual override with
      dedicated processor and stand-alone power supply (fixed wing use)
    • - Backup system integrates mixing, providing consistent autopilot and manual
      override mixing modes (fixed wing use)
    • - Redundant power supply inputs and automatic failover
    • - External safety switch
    • - Multicolor LED main visual indicator
    • - High-power, multi-tone piezo audio indicator
    • - microSD card for high-rate logging over extended periods of time
    Sensori:
    # ST Micro L3GD20H 16 bit giroscopio Link
    # ST Micro LSM303D 14 bit accelerometro / magnetometro Link
    # MEAS MS5611 barometro Link
    Interfacce:
    # 5x UART (porte seriali)
    # 2x CAN
    # Spektrum DSM / DSM2 / DSM-X ®
    # Input e Output compatibile con Futaba S.BUS ®
    # PPM sum signal
    # RSSI (PWM or voltage) input
    # I2C ®
    # SPI
    # Ingressi 3,3 e 6,6 V ADC
    # Porta microUSB
    Sistema di alimentazione:
    # Diodo controller con failover automatico
    # Servo rail high-power (7V) and high-current ready
    # Tutte le uscite protette da overvolt e protetti tutti gli ingressi ESD
    Peso e dimensioni:
    # Peso: 38g (1,31 once)
    # Larghezza: 50 mm (1.96 ")
    # Spessore: 15,5 mm (.613 ")
    # Lunghezza: 81,5 mm (3,21 ")
    Link Utili:
    - APM | Open source autopilot
    - https://pixhawk.ethz.ch/px4/modules/pixhawk
    - https://store.3drobotics.com/products/3dr-pixhawk
    Guida settaggi PID Arducopter
  • #2
    Ma è disponibile? Fino a qualche giorno fa era solo possibile il pre-order e ora è in back order. ..boh...
    ...ma qui mi sa che per un po' Egisto non vincerà. ..
    Ultima modifica di TermicOne; 07 ottobre 13, 12:36.
    TermicOne su youtube
    Commenta
    • #3
      Originariamente inviato da TermicOne Visualizza il messaggio
      O almeno finchè non ci saranno reali ed evidenti salti in avanti rispetto ad APM, almeno per quello che mi riguarda...
      Ma visto che si tratta di una novità, va seguita!!!!!!!!!
      Meme
      Commenta
      • #4
        Mi fa sbavare, resto sintonizzato !
        Commenta
        • #5
          Aspettavo L'apertura si questo 3d
          Inviato dal mio HUAWEI Y300-0100 con Tapatalk 2
          Commenta
          • #6
            Rimane uno dei progetti che sostituiranno l'attuale APM ..vediamo un po gli sviluppi
            Commenta
            • #7
              Originariamente inviato da gibon Visualizza il messaggio
              quotone!
              Thunder Tiger SSK, Serpent Impact 10 dell'anteguerra, Multiplex easyglider, Turnigy er9x
              Commenta
              • #8
                Il mio punto di vista è che attualmente non ci siano molte differenze tra la scheda apm 2.6 originale, quella che utilizza il processore ad 8 bit compresi i vari cloni hobbyking e arduflyer, e i progetti a 32 bit VrBrain e Pixhawcks. Infatti attualmente questi ultimi 2 non sono altro che un porting del codice APM ad 8 bit, gli algoritmi sono sempre gli stessi scritti per la potenza limitata dell' 8 bit e quindi approssimati nel calcolo con molti workaround e cicli di loop lenti. (lentezza di loop che rende gli algoritmi molto piu' sensibili alle vibrazioni )
                Soltanto staccandosi dal codice originale APM e scrivendo per il 32bit si noteranno vere differenze.
                Ultima modifica di danveal; 07 ottobre 13, 15:35.
                Quadricottero News
                http://www.facebook.com/Quadricottero
                Commenta
                • #9
                  a livello teorico l'intento di 3DR è quello di staccarsi completamente da APM per sfruttare la nuova architettura.. poi se voglia dare solo questa sensazione ma non lo faccia è quello che vorrei capire... ( 30 milioni possono essere tanti o pochi..dipende verso che risorse sono indirizzati.. e qual'è il fine reale dell'investimento ).
                  Purtroppo già in altri settori anche professionali abbiamo avuto esperienza storiche di eccezionali miglioramenti tecnologici che in realtà non erano sfruttati realmente ( vedi l'hardware a 64bit dei PC ..., addirittura software CAD di fascia medio/alta che non erano in grado di sfruttare i sistemi multiprocessore mentre i rivenditori vendevano workstation a 4 e piu' processori dicendo che era indispensabile e che si sarebbe risparmiato tantissimo tempo..ecc ecc ).
                  Commenta
                  • #10
                    C'e' da considerare che APM è sponsorizzato da 3DR, quel che vedrei piuttosto è l'evoluzione di APM verso la nuova architettura STM32 (il fatto che su procio a 8bit non è più possibile usare gli Okto è il segnale che non basta più).
                    Il software APM non è poi cosi' legato all'8-bit dalla versione 3.x grazie al livello di astrazione (in pratica c'e' bisogno di driver per l'hardware).
                    Occhio però che a quanto vedo il driver per PX4 è molto acerbo.
                    px4=nightmare. Ma come tutti sanno ci vuole tempo prima di avere stabilità.
                    Informatico Professionista, Amante dei 4x4 e delle auto ibride, costruttore di quadricotteri.
                    Commenta
                    • #11
                      Originariamente inviato da ciskje Visualizza il messaggio
                      Il dover sostenere un OS anche se real time secondo te/voi potrebbe creare complicazioni e defiance in casi particolari? Nel senso...ci potrebbero essere microritardi di risposta per eventuali sovraccarichi di dati oppure è ipotesi pressochè impossibile? ( in altre applicazioni sarebbe veniale su un quadri ritardi di decisimi di secondo potrebbero creare problemi ). Lo chiedo innocentemente per sapere se c'è chi ha esperienza concreta con OS real time.
                      Commenta
                      • #12
                        quando esce il clone ... ?
                        comoda la possibilità di avere una porta USB "volante".
                        La bibbia dei Bladoni V6, Blade 120SR - Guida Crius Aio Pro V1.3
                        ATOM 500 - Blade 400 FBL STRETCHED 6s - 120SR.
                        Commenta
                        • #13
                          sarebbe il futuro MP o non c'entra nulla ?
                          https://pixhawk.ethz.ch/px4/downloads
                          Commenta
                          • #14
                            Originariamente inviato da kawa78 Visualizza il messaggio
                            E' la nuova versione del QGround Control , non e' il nuovo mission planner .
                            Le nostre applicazioni usano e condividono lo stesso protocollo di comunicazione mavlink e quindi sono compatibili con diversi ground station software sia su pc che pad. Diciamo che e' come parlare di droidplanner o andropilot.
                            un saluto
                            Roberto
                            Redfox74
                            Virtual Robotix ( Arducopter DEVTEAM )
                            http://www.virtualrobotix.com
                            Canale di supporto FB
                            https://www.facebook.com/groups/1606596929592397/
                            Commenta
                            • #15
                              Grazie Roberto. Magari potevo approfondire prima di chiedere.. Che forse era ovvio leggendo bene. In ogni caso non ho dubbi adesso.
                              Commenta
                              Sto operando...
                              X
