Vecchio 27 dicembre 07, 13:06   #1 (permalink)  Top
L'avatar di ron_van_sommeren
Data registr.: 26-12-2003
Residenza: near Nijmegen, the Netherlands
Building a Macchi C.202 Folgore,1:9
Designed by user 'W@CCO' (= Tom van Haaren) from Belgium, he had it lasercut by Manzano Laser (USA). Will be availabe as a 'short kit' from Manzano later.
Span: 1176mm
Lengte: 983
Motorisatie elektrisch.
Pictures:
http://www.modelbouwforum.nl/forums/...ad.php?t=45639
If you have questions/information, we/they don't mind English
Vriendelijke groeten ;) Ron van Sommeren
• int. electric fly-in, Nijmegen, the Netherlands
• brushless motor building tips & tricks
• diy brushless motor discussion group
• Drive Calculator download & discussion group
Ultima modifica di ron_van_sommeren : 27 dicembre 07 alle ore 13:13
ron_van_sommeren non è collegato   Rispondi citando
Vecchio 27 dicembre 07, 20:13   #2 (permalink)  Top
Originalmente inviato da agomago
Lo stesso su RC groups in inglese.
http://www.rcgroups.com/forums/showthread.php?t=701416
Ago
Merci Ago
Vecchio 29 dicembre 07, 10:32   #3 (permalink)  Top
Data registr.: 29-12-2007
Residenza: Duffel; Belgium
--maybe I better continue here cause it is more on topic in the electric forum.--
Thank you for being a messenger boy Rob. Else I would never have thought on posting on an Italian forum.
As said previously by Rob,
Scale is 1/9th, span 1176mm and length 983mm
It will be powered with an electric brushless motor on 3 lipo's of 3700 mah turning an 8.5 x 7 or 8.5 x 5 aeronaut glass-e proppelor.
Construction is entirly in wood. THe wing is all balsa with a couple of ply reinforcements. The fuselage is made arround a ply frame that is planked with 2.5mm balsa. Tail and stabilizer are in Balsa. Aiming weight is under 1.5 kg
It will be finished in the colors of a 369sq, 22gruppo plane.
The sandcolor, gray and green meandering lines are airbrushed. The other things are hand painted.
Here are some pictures of the plane.
Greetings
Tom
Ultima modifica di W@CC0 : 29 dicembre 07 alle ore 10:39
W@CC0 non è collegato   Rispondi citando
Vecchio 29 dicembre 07, 19:16   #4 (permalink)  Top
L'avatar di agomago
Data registr.: 21-11-2003
Residenza: Cittadella PD
Immagini: 15
W@cco
Bel modello
BRAVO complimenti
Sarebbe un buon soggetto per PSS
Ago
agomago non è collegato   Rispondi citando
Vecchio 29 dicembre 07, 23:26   #5 (permalink)  Top
In depron:
http://www.rcgroups.com/forums/showthread.php?p=8816011
Vecchio 30 dicembre 07, 01:49   #6 (permalink)  Top
L'avatar di 2M86
Data registr.: 26-12-2004
Immagini: 16
Tom,
vraiment un beau travail!!!
Salut!
2M86 non è collegato   Rispondi citando
Vecchio 03 gennaio 08, 23:18   #7 (permalink)  Top
Thank you for the kind words
The emblems and symbols of the squadron and stormo and the Italian air force are in place.
The Savioa insigne, the scarecrow and the facses are decals I made myself. First I searched for the pictures of it. Then, the scarecrow and fasces were cleaned up in photoshop. The Savioa insigna was big and sharp enough. It was provided by an Italian called Enrico, on Rcgroups.
Then, they were laser printed and glued on the plane with white glue. When it was dry, I varnished them to seal them and to make them water proof.
The numbering on the fuselage was hand painted.
Tom
Vecchio 06 aprile 08, 15:22   #8 (permalink)  Top
Videos, building and flying
Macchi C.202 Folgore (2)
Vecchio 24 aprile 08, 18:19   #9 (permalink)  Top
Tom's design is now available as a short kit from Manzano Laser Works , 75$.
Vecchio 16 agosto 08, 18:55   #10 (permalink)  Top
Construction manual available online:
Macchi C. 202 Folgore - Page 15 - RC Groups
Prettig weekend Ron
Building a Macchi C.202 Folgore, pictures ron_van_sommeren Aeromodellismo 12 16 agosto 08 18:57
building log Fox 2.8m edo volante Aeromodellismo Alianti 230 16 luglio 08 18:07
macchi 202... Amiko92 Categoria Rc-Combat 14 29 novembre 07 17:23
Macchi 202 Folgore Mau89 Aeromodellismo Progettazione e Costruzione 2 01 ottobre 05 14:15
Tutti gli orari sono GMT +2. Adesso sono le 05:14.
