OpenTX 2.2.3 disponibile
Main changes since 2.2.2
R9M: support for Flex firmware, clarified 1W level (auto-adjust up to 1W on current R9M firmware)
GasSuite: fix telemetry for newer firmwares (requires sensor delete and rescan)
X7/X9E/Horus: power button is now considered as a key for backlight operation
X7/X9E/Horus: allow shutdown while model notes are displayed
xlite: fix telemetry bars settings field
ARM non FrSky radios: add bindings options for XJT module
All radios with PAGE key: prevent page change during editing
FlySky telemetry : treat volts data as signed values
Crossfire/X9E: standardise wheel direction in Crossfire lua scripts
Companion: fix PREC2 telemetry data offset transfers
Companion: fix model compare switch warning for Horus (Thx Elecpower)
Companion: fix GVAR popup handling
Companion: Remove stale top bar setting for Horus
Companion: fix telem. sensor offset decimals not updating properly when precision is changed
Companion: fix file editor paste/insert actions not properly updating when clipboard data changes externally
Companion: Release notes menu item now points to the open-tx.org website
Companion: Display filename in model edit window title
Simulator: fix mixer outputs monitor not updating when channel value hasn’t change
Simulator: fix telemetry simulator A3 & A4 values not being sent properly
Simulator: fix telemetry simulator log reader parsing for “Cels(V)” column
Multiprotocol: new protocols added (thx MRC3742)
Horus bootloader: Rotary encoder operation fixed (no more need for 2 clicks per line)
Speech: Dutch added/fixed
