Originalmente inviato da mauromgi questi i dati del peoduttore. LEDF50-1A46
Alloy EDF 4600kv(3s - Outrunner Version)
Specification:
♦ Rotor size: 50mm/5blades
♦ Sell No.: 3S
♦ Weight (Total): 65g
♦ MAX RPM: 54000
♦ MAX Power (10sec.) Watt: 210
♦ Continuous Power Watt: 195
♦ Motor size: 2030L
♦ Kv: 4600
♦ Voltage: 11.1V
♦ Current: 17A
♦ Thrust Power Upto: 0.44kg
♦ Inner Dia: 50mm
♦ Outer Dia: 52mm
♦ESC(timing): Higher Quanto al modello dovrei stare sui 400gr. |
ah se stai sui 400 gr completo allora ce la dovrebbe fare...
