sto tentando in tutte le maniere di settare questo modulo gps x una apm ardupilot 2.5 ma non riesco propio ..ho letto tutti i tread che avete posto in evidenza e non ed ho quindi risolto parecchie magagne ma adesso sono ad un punto morto...mi aiutate x favore durante l uploading oltre a riscontrare quel messaggino di incompatibilita che avete scritto di ignorare riscontro problemi di scrittura guardate il report che dice>>
Sending: MON-VER - B5 62 0A 04 00 00 0E 34 ...
... timeout occurred without receiving an answer. Retrying...!
Sending: MON-VER - B5 62 0A 04 00 00 0E 34 ...... failed due to timeout!
Sending: MON-VER - B5 62 0A 04 28 00 37 2E 30 33 20 28 34 35 39 36 39 29 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 34 30 30 30 37 00 00 0B B0 ...
Version check: there were conflicts! --> download continued by user...
Sending: CFG-ANT - B5 62 06 13 04 00 1B 00 8B A9 6C F8 ...
Sending: CFG-ANT - B5 62 06 13 04 00 1B 00 8B A9 6C F8 ... failed due to timeout!
Sending: CFG-DAT - B5 62 06 06 02 00 00 00 0E 4A ...
Sending: CFG-FXN - B5 62 06 0E 24 00 0C 00 00 00 00 00 00 00 00 00 00 00 10 27 00 00 10 27 00 00 D0 07 00 00 18 FC FF FF 00 00 00 00 00 00 00 00 9B 8A ...
Sending: CFG-INF - B5 62 06 02 0A 00 00 00 00 00 00 00 00 00 00 00 12 E6 ...
Sending: CFG-INF - B5 62 06 02 0A 00 01 00 00 00 87 87 87 87 87 87 3D 03 ...
Sending: CFG-INF - B5 62 06 02 0A 00 03 00 00 00 00 00 00 00 00 00 15 04 ...
Sending: CFG-ITFM - B5 62 06 39 08 00 F3 AC 62 2D 1E 03 00 00 96 05 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 01 00 00 00 00 00 00 11 B2 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 02 00 01 00 00 00 00 13 BE ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 03 00 01 00 00 00 00 14 C5 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 04 00 00 00 00 00 00 14 C7 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 06 00 00 00 00 00 00 16 D5 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 11 00 00 00 00 00 00 21 22 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 12 00 01 00 00 00 00 23 2E ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 20 00 00 00 00 00 00 30 8B ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 21 00 00 00 00 00 00 31 92 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 22 00 00 00 00 00 00 32 99 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 30 00 00 00 00 00 00 40 FB ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 31 00 00 00 00 00 00 41 02 ...
Sending: CFG-MSG - B5 62 06 01 08 00 01 32 00 00 00 00 00 00 42 09 ...
Sending: CFG-MSG - B5 62 06 01 08 00 02 20 00 00 00 00 00 00 31 93 ...
Sending: CFG-MSG - B5 62 06 01 08 00 02 23 00 00 00 00 00 00 34 A8 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 02 00 00 00 00 00 00 1B 01 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 05 00 00 00 00 00 00 1E 16 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 06 00 00 00 00 00 00 1F 1D ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 07 00 00 00 00 00 00 20 24 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 08 00 00 00 00 00 00 21 2B ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 09 00 00 00 00 00 00 22 32 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 0A 00 00 00 00 00 00 23 39 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 20 00 00 00 00 00 00 39 D3 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0A 21 00 00 00 00 00 00 3A DA ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 00 00 00 00 00 00 00 1A FB ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 05 00 00 00 00 00 00 1F 1E ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 30 00 00 00 00 00 00 4A 4B ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 31 00 00 00 00 00 00 4B 52 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 32 00 00 00 00 00 00 4C 59 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0B 33 00 00 00 00 00 00 4D 60 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0D 01 00 00 00 00 00 00 1D 12 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0D 03 00 00 00 00 00 00 1F 20 ...
Sending: CFG-MSG - B5 62 06 01 08 00 0D 06 00 00 00 00 00 00 22 35 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 00 01 00 01 01 01 01 04 33 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 01 01 00 01 01 01 01 05 3A ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 02 01 00 01 01 01 01 06 41 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 03 01 00 01 01 01 01 07 48 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 04 01 00 01 01 01 01 08 4F ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 05 01 00 01 01 01 01 09 56 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 06 00 00 00 00 00 00 05 4D ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 07 00 00 00 00 00 00 06 54 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 08 00 00 00 00 00 00 07 5B ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 09 00 00 00 00 00 00 08 62 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F0 0A 00 00 00 00 00 00 09 69 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F1 00 00 00 00 00 00 00 00 2B ...
Sending: CFG-MSG - B5 62 06 01 08 00 F1 03 00 00 00 00 00 00 03 40 ...
Sending: CFG-MSG - B5 62 06 01 08 00 F1 04 00 00 00 00 00 00 04 47 ...
Sending: CFG-NAV5 - B5 62 06 24 24 00 FF FF 03 03 00 00 00 00 10 27 00 00 05 00 FA 00 FA 00 64 00 2C 01 00 3C 00 00 00 00 00 00 00 00 00 00 00 00 4F 82 ...
Sending: CFG-NAVX5 - B5 62 06 23 28 00 00 00 FF FF 03 00 00 00 03 02 03 10 07 00 00 01 00 00 43 06 00 00 00 00 01 01 00 01 00 64 78 00 00 00 00 00 00 00 00 00 9A A7 ...
Sending: CFG-NMEA - B5 62 06 17 04 00 00 23 00 02 46 54 ...
Sending: CFG-PM - B5 62 06 32 18 00 00 06 00 00 04 90 00 00 E8 03 00 00 10 27 00 00 00 00 00 00 02 00 00 00 0E 0A ...
Sending: CFG-PM2 - B5 62 06 3B 2C 00 01 06 00 00 00 90 02 00 E8 03 00 00 10 27 00 00 00 00 00 00 02 00 00 00 2C 01 00 00 4F C1 03 00 86 02 00 00 FE 00 00 00 64 40 01 00 95 C5 ...
Sending: CFG-PRT - B5 62 06 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A 48 ...
Polling CFG-PORT of port 0... failed due to timeout!
Sending: CFG-PRT - B5 62 06 00 14 00 01 00 00 00 C0 08 00 00 00 96 00 00 07 00 01 00 00 00 00 00 81 84 ...
... successfully completed after poll!
Sending: CFG-PRT - B5 62 06 00 14 00 02 00 00 00 C0 08 00 00 80 25 00 00 00 00 00 00 00 00 00 00 89 7F ...
Polling CFG-PORT of port 2... failed due to timeout!
Sending: CFG-PRT - B5 62 06 00 14 00 03 00 00 00 00 00 00 00 00 00 00 00 07 00 07 00 00 00 00 00 2B E6 ...
Sending: CFG-PRT - B5 62 06 00 14 00 04 00 00 00 00 32 00 00 00 00 00 00 07 00 07 00 00 00 00 00 5E E8 ...
Polling CFG-PORT of port 4... failed due to timeout!
Sending: CFG-RATE - B5 62 06 08 06 00 64 00 01 00 01 00 7A 12 ...
Sending: CFG-RINV - B5 62 06 34 18 00 00 4E 6F 74 69 63 65 3A 20 6E 6F 20 64 61 74 61 20 73 61 76 65 64 21 00 F9 D0 ...
Sending: CFG-RXM - B5 62 06 11 02 00 08 00 21 91 ...
Sending: CFG-SBAS - B5 62 06 16 08 00 00 03 03 00 51 62 06 00 E3 27 ...
Sending: CFG-TP - B5 62 06 07 14 00 40 42 0F 00 A0 86 01 00 01 01 00 00 32 00 00 00 00 00 00 00 0D 6C ...
Sending: CFG-TP5 - B5 62 06 31 20 00 00 00 00 00 32 00 00 00 40 42 0F 00 40 42 0F 00 00 00 00 00 A0 86 01 00 00 00 00 00 F7 00 00 00 C9 97 ...
Sending: CFG-TP5 - B5 62 06 31 20 00 01 00 00 00 32 00 00 00 04 00 00 00 01 00 00 00 48 E8 01 00 A0 86 01 00 00 00 00 00 FE 00 00 00 E5 41 ...
Sending: CFG-USB - B5 62 06 1B 6C 00 46 15 A6 01 00 00 00 00 64 00 00 01 75 2D 62 6C 6F 78 20 41 47 20 2D 20 77 77 77 2E 75 2D 62 6C 6F 78 2E 63 6F 6D 00 00 00 00 00 00 75 2D 62 6C 6F 78 20 36 20 20 2D 20 20 47 50 53 20 52 65 63 65 69 76 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 DC ...
Sending: CFG-CFG - B5 62 06 09 0C 00 00 00 00 00 FF FF FF FF 00 00 00 00 17 75 ...
ATTENTION: There were errors/conflicts!
Please verify.
a qualcuno e successo? e un problema di velocita?
Please verify.
Commenta
