annuncio
Comprimi
Ancora nessun annuncio.
DJI Lightbridge HD video transmission
Comprimi
X
  • Filtro
  • Ora
  • Visualizza
Elimina tutto
nuovi messaggi
  • DJI Lightbridge HD video transmission
    Novità dji
    DJI Lightbridge is DJI upcoming 2.4G Full HD digital video transmission system, the maximum transmission 1920 * 1080p @ 30fps full HD video data, measured the effective transmission distance up to 1.7km, FPV enthusiasts and professional aerial essential artifact!
    File x Dimensionamento multirotori http://www.baronerosso.it/forum/4304186-post101.html
    Manuali Ita DJI
    https://dl.dropboxusercontent.com/u/...0DJI%20ita.zip
  • #2
    Originariamente inviato da Blade-slap Visualizza il messaggio
    Novità dji
    Prima o poi doveva succedere...
    Clicca la mia pagina di Aeromodellismo su Facebook
    Commenta
    • #3
      Trovato anche il link del Video
      DJI Lightbridge
      Manuali Ita DJI
      Commenta
      • #4
        DJI Lightbridge
        Ciao Blade, hai notato che nel video non utilizzano apperecchi Apple?
        Commenta
        • #5
          Mi sono accorto che forse andava messo in un altra sezione
          quella dell'video o fpv
          pazienza
          First, the characteristics
          · 2.4G Full HD digital transmission
          - Digital video transmission, input supports up to 1920 * 1080 @ 60fps , output up to 1920 * 1080 @ 30fps ;
          · Distance
          - Use 2.4G RF technology, transmitting power 100mw (CE and FCC certification);
          - Ground terminal with 5dbi omni-directional antenna (standard), measured the effective transmission distance of 1.7km (1.05mile);
          - Ground terminal with 14dbi directional antenna (optional), measured the effective transmission distance up to 5km (3.1mile);
          • Multiple video input and output formats
          - AV input;
          - HDMI input;
          - USB 2.0 Full HD video output: IOS, Android and other mobile phones, tablet PCs do monitor via USB connection using;
          - HDMI HD video output;
          · Built-in remote link
          - Downlink and uplink remote video link system while working at 2.4Ghz;
          - Ground terminal via remote control coach to get the remote control port data sent to the client through the sky uplink, downlink synchronization with the video link, without disturbing each other;
          - Ground terminal controller supports two simultaneous input Lu Yao, were used as aircraft control and PTZ control, the sky receives transmitted to the master via DBUS;
          • Immunity
          - Uplink frequency hopping (FHSS) + Spread Spectrum (DSSS) technology, high transmission stability, strong anti-jamming capability;
          - Downlink MIMO multiple antenna technology and using OFDM modulation, with advanced algorithms to effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system;
          - Real-time monitoring of each downlink channel interference state, dynamically select the best channel operation (up to 8 image transmission channels);
          - Same time and can support up to eight devices simultaneously sets Lightbridge;
          • Low Latency
          - System maximum delay 80ms;
          • OSD function
          - Built-in OSD function, with NAZAV2, WKM, A2 use when no external IOSD, information overlay function can be realized;
          • Bundled flight controllers
          - Equipment must NAZA V2, WKM, A2 used in conjunction with the master;
          • Multi-slave mode and Information Security
          - End single sky and simultaneously work with multiple ground terminal (only one ground terminal to transmit control data, the device can only receive the rest of the video);
          - Data encryption transmission, only after the ground terminal on the frequency authorized to receive video data to ensure information security;
          • Large-capacity rechargeable battery and the external
          - Built-in 4000mAh high capacity ground terminal battery, the device can work for 4.5 hours;
          - Standard charger or battery could 3s-6s, charging only 1.5h;
          - Battery power LED visual indication;
          - Through the USB external mobile devices, providing the charging function for mobile devices, an external device to extend the use of time;
          Second, Specifications
          Video Input HDMI, AV, DVSB
          Supported formats (HDMI) 720P50; 720P60; 1080I50; 1080I60; 1080P25; 1080P30; 1080P50; 1080P60;
          Supported formats (AV) PAL25; NTSC30
          RF parameters 2.405 ~ 2.4835GHz, comply with CE, FCC certification
          Interface (ground side) LED lights; power switch; charging port; USB 2.0; HDMI; remote control inputs (two Luyao controller input)
          Interface (Sky end) LED lights; DBUS; HDMI; AV; DVSB; keys for frequency
          Material Aluminum
          Power supply (ground terminal) DC power input 11 ~ 26V; built-in lithium battery; Consumption: 6W (no external USB device), 8W (external USB device)
          Power (Sky end) DC power input 11 ~ 26V; Power consumption: 8W
          Dimensions (ground side) 125 * 89 * 20 (mm)
          Dimensions (Sky end) 67 * 47 * 20 (mm)
          Weight (ground side) 360g
          Weight (Sky end) 70g
          Manuali Ita DJI
          Commenta
          • #6
            Originariamente inviato da Roby1960 Visualizza il messaggio
            Era ora no?!!!!!
            Manuali Ita DJI
            Commenta
            • #7
              Era ora no?!!!!!
              Sicuramente è una soluzione per allargare l'interesse
              Chissà quanto costa
              Commenta
              • #8
                alcune immagini dell'Hardware
                Prezzo da definire forse Verra anche dato in bundle con l'A2
                ma questa è una butade di un tizio che scrive su forum cinese
                Ultima modifica di Blade-slap; 16 giugno 14, 07:45.
                Manuali Ita DJI
                Commenta
                • #9
                  L'uscita video RX solo HDMI e USB è indirizzata ad apparecchi mobile però se c'era anche AV non era male
                  Commenta
                  • #10
                    roba da pazzii...
                    On Facebook Quadricottero News
                    Guida per MicroQuad da FPV
                    Commenta
                    • #11
                      L'AV lo puoi ottenere con un convertitore HDMI PAL/NTSC, costano una ventina di Euro e vanno abbastanza bene.
                      Commenta
                      • #12
                        Grande dji, però in 2.4 non va in conflitto con la radio che è in 2.4 e tutte e due in digitale!
                        Vivo di piccole cose, ma molto spinte..
                        Commenta
                        • #13
                          Ma piú che altro,visto che molti usano gli occhiali per volare in fpv non so se esistano occhiali che supportino una tale risoluzione.....alla fine saremo sempre limitati dal display/occhiali che andremo ad utilizzare.Magari i cinemizer sono all'altezza ma hanno un prezzo fuori mercato
                          Commenta
                          • #14
                            Gli occhiali ci sono sia della fatshark che escono ad aprile e della zeis, per di più ci sono anche le cam piccole in hd senza montare gopro o altro, così si ha un risparmio di peso.
                            Commenta
                            • #15
                              Originariamente inviato da Giobbanni79 Visualizza il messaggio
                              No no, la risoluzione della trasmissione era proprio il collo di bottiglia che non permetteva di fare FPV in FULLHD, adesso tra cinemizer, i nuovi oculus rift e i futuri fatshark, per non parlare dei dspaly/monitor che si trovano in commercio e i tanti schermi di cellulari che alcuni sono arrivati gia a 2k.
                              Diciamo che come prodotto sarebbe stupendo perchè almeno la frequenza è legale, la potenza non la so, ma potrebbe anche esserlo.
                              l'unico problema dopo è quale frequenza usare per la radio..
                              Commenta
                              Sto operando...
                              X
