09 agosto 17, 19:21 | #11 (permalink) Top |
User Data registr.: 21-05-2006 Residenza: Near Monza
| Forse è l'esc andato, ma anche se suona e la rx l'alimenta prova a fare il bind lo stesso poi vedi cosa succede, se non fa il bind non riceve segnale dalla rx, per cui magari quel modello di esc suona continuamente, provare non costa nulla.
__________________ - WIGENS F3A 2mt - HYDEOUT F3A 2mt - SATURN F3A 2mt - YAK 55 73" - CALYPSO F3A http://www.youtube.com/watch?v=1BT9OLdXy58 |
10 agosto 17, 14:06 | #12 (permalink) Top |
Adv Moderator Data registr.: 10-05-2008 Residenza: Roseto (TE)
da google, digita "scorpion commander 25A manual" il primo link seguilo, è il PDF (se non lo hai gia) a pagina 2 troverai il setup per minimo e max gas, altrimenti lui non riconosce nulla. Copio e incollo: (ma consiglio download del PDF) 4.0 Initial setup You MUST perform throttle range setup before the rst use of the ESC. Remove propeller/pinion from motor while performing initial throttle range setup. 4.1 Turn on transmitter and set throttle to maximum position be sure that your throttle is set at 0% minimum throttle and 100% at maximum throttle 4.2 Place the switch on the IR receiver to IRS (see section 5.0) Connect battery to ESC. After few seconds you will hear 3 beeps come from the motor to indicate you are in program mode. 4.3 With your throttle to maximum position place the switch on the IR receiver to PPM. After a few seconds you will hear 2 beeps come from the motor, once you have heard these two peeps move your throttle to minimum position within 10 seconds and hold throttle at minimum position. Then you will hear 2 beeps indicating minimum throttle position is set and conrmed. Your ESC will also arm after you have set the minimum position. You only need to do this once as throttle range will be stored in the memory of the speed controller. You can reset the throttle range by performing steps 4.1 to 4.3 again.
__________________ Oxy 5, Logo 600SX |
10 agosto 17, 16:22 | #13 (permalink) Top | |
__________________ - WIGENS F3A 2mt - HYDEOUT F3A 2mt - SATURN F3A 2mt - YAK 55 73" - CALYPSO F3A http://www.youtube.com/watch?v=1BT9OLdXy58 | |
10 agosto 17, 16:29 | #14 (permalink) Top | |
un'altra rx da provare non ci sta ?
__________________ Oxy 5, Logo 600SX | |
Strumenti discussione | |
Visualizzazione | |
potete aiutarmi a scegliere??? | lucandroid00 | Aeromodellismo Volo a Scoppio | 2 | 10 giugno 14 17:11 |
Triton jr, potete aiutarmi? | bonzo76 | Batterie e Caricabatterie | 12 | 30 giugno 13 00:53 |
Potete aiutarmi a trovare un modo per contare i giri di un motore elettrico? | zikikio | Circuiti Elettronici | 20 | 21 ottobre 12 17:32 |
Potete aiutarmi per cortesia... | Breva850 | Ferromodellismo | 4 | 15 ottobre 10 12:53 |
Potete aiutarmi?? | Entony93 | Automodellismo Mot. Scoppio On-Road | 24 | 17 luglio 08 14:27 |
