Torna indietro   BaroneRosso.it - Forum Modellismo > Categoria Elimodellismo > Elimodellismo in Generale e Vecchi Topic
Registrazione Gallery FAQ Lista utenti Calendario Cerca I messaggi di oggi Segna forums come letti
Strumenti discussione Cerca nella discussione Visualizzazione
Vecchio 07 aprile 08, 14:22   #1 (permalink)  Top
L'avatar di honey_bee
Data registr.: 10-12-2006
Invia un messaggio via MSN a honey_bee
Servi Alternativi, chi li ha provati
Chi ha provato servi alternativi ai soliti futaba?
Girando in rete ho torvato i cinesi
towerPro TowerPro MG995 Servo
http://www.rcsmart.com/images/servomg99501.jpg
- Dimensions: 1.57" x 0.79" x 1.44" (40 x 20 x 36.5mm)
- Weight: 1.78oz (48g)
- Operating Speed (4.8V no load) : 0.17sec / 60 degrees
- Operating Speed (6.0V no load) : 0.13sec / 60 degrees
- Stall Torque (4.8V): (13kg/cm) (180oz/in.)
- Stall Torque (6.0V): (15kg/cm) (208oz/in.)
- Temperature Range: -30 to +60 Degree C
- Dead Band Width: 4usec
- Operation Voltage: 3.5 - 8.4Volts
Model: HD-9150MG
http://www.pitstop-shop.nl/media/hd9110_0030_8.jpg
Voltage: 4.5v~7.2v
Speed: .17sec
Torque: 15.8kg/cm
Bearings: 2BB
Gears: Metal
Weight: 60g
Model: HD-9110MG
Voltage: 4.5v~7.2v
Speed: .19sec
Torque: 10.5kg/cm
Bearings: 2BB
Gears: Metal
Weight: 49g
MG996R
http://www.hobbycity.com/hobbycity/s...log/MG996R.jpg
This is essentially an upgraded version of the famous towerpro MG995 servo. It now has a redesigned PCB and IC controll system which makes it far more accurate. Its internal gearing and motor are also upgraded to improve dead bandwith and centering.
All specifications are the same as the previous model MG995, however this servo is far more accurate, and safe to use in aircraft which require precise servo movements and perfect centering.
Weight- 53.0g
Dimension 40.7*19.7*42.9mm
Stall torque 10kg/cm
Operating speed 0.20sec/60degree(4.8v)
Operating voltage 4.8-7.2V
Temperature range 0Ž_ 55Ž
Servo Plug: JR (Fits JR and Futaba)
honey_bee is offline   Rispondi citando
Vecchio 07 aprile 08, 15:57   #2 (permalink)  Top
L'avatar di albx
Data registr.: 05-04-2005
Residenza: Salerno - provincia
Hobbycity Online R/C Hobby Store : SCR 48g / 7.4kg-cm / .11sec Metal Gear Servo $19.95
io da poco ho montato questi... sono velocissimi...
Style 30 - MiniTitan - SJM430
Hyperion EXTRA 300 10e - Topstick
albx is offline   Rispondi citando
Vecchio 07 aprile 08, 16:57   #3 (permalink)  Top
Ciao, grazie della risposta! Su che modello li hai montati?
Vecchio 07 aprile 08, 19:43   #4 (permalink)  Top
L'avatar di sberla76
Data registr.: 18-09-2005
Residenza: Livorno
Invia un messaggio via MSN a sberla76
Ciao Honey Bee,
Io ho provato i Tower pro. Giā a 4,8 V tirano bene ma sono estremamente imprecisi e quasi mai tornano al centro. Ho provato a montarli sul mio Sceadu ma ho dovuto rismontare tutto e tornane ai miei cari Futaba 3152.
Ora azionano i carrelli del mio Bell 222.
Saluti.
A.
sberla76 is offline   Rispondi citando
Vecchio 07 aprile 08, 20:24   #5 (permalink)  Top
chissā se con i 996r hanno risolto questo difetto...sarei tentato dal prenderne uno e testarlo.
Vecchio 08 aprile 08, 11:58   #6 (permalink)  Top
L'avatar di albx
Originalmente inviato da honey_bee Visualizza messaggio
Ciao, lo style 30
Vecchio 08 aprile 08, 16:41   #7 (permalink)  Top
L'avatar di pichi
Data registr.: 09-11-2007
Residenza: Novi Ligure
Originalmente inviato da sberla76 Visualizza messaggio
Ciao Honey Bee,
Saluti.
A.
Carrelli del tuo BELL????? Allora lo hai finito!!!!
Posta foto...
Ciaooo
Freya Evolution - Yamada 91 SR / Hirobo SWM Sceadu 50 SDX- OS 50 SX / Mini Titan E325 / Kyosho Calmato 40 sport / Yak 54 Mattfly 2.2 a.a. - DL 50 / Tucano 120 - OS 120 4t
Futaba T10
pichi is offline   Rispondi citando
Vecchio 08 aprile 08, 17:53   #8 (permalink)  Top
L'avatar di hirobo-max
Data registr.: 31-01-2008
Residenza: Foggia
Io ho provato per un periodo i TowerPro MG995 sono molto potenti....ma imprecisissimi.....valgono il prezzo che costano
hirobo-max is offline   Rispondi citando
Vecchio 08 aprile 08, 18:30   #9 (permalink)  Top
L'avatar di AlexxZeta
Data registr.: 27-03-2005
Residenza: Firenze
Invia un messaggio via ICQ a AlexxZeta Invia un messaggio via MSN a AlexxZeta Invia un messaggio via Yahoo a AlexxZeta Send a message via Skype™ to AlexxZeta
Giā li ho provati anch'io. Non sono tutti uguali, alcuni funzionano decentemente altri no...Bisogna avere fortuna, comunque il vero problema di questi servi č che 5 volte su 10 non tornano perfettamente al centro per cui, in special modo per gli elicotteri, sono poco indicati.. Ma in generale li sconsiglio per qualsiasi applicazione "seria".. (al massimo per un uso su carrelli retrattili..possono andare)
Immaginate che brutta figura, un pilota F3A, il cui aereo ha degli alettoni che non tornano in posizione neutra...a me č capitato..Un vero macello!
AlexxZeta is offline   Rispondi citando
Vecchio 28 aprile 08, 01:01   #10 (permalink)  Top
L'avatar di Scuba
Data registr.: 16-01-2006
Un mio amico me li ha fatti montare sul suo ely, risultato: levati dopo il primo volo .
Sono rumorosissimi, hanno giochi , la fluidita' nel movimento č un optional.
Sono delle cinesate che non valgono nemmeno la cifra che ti chiedono, piuttosto metti i hs 475 dell'Hitec costano poco e vanno bene , solo su raptor e style , usa per il collettivo un servo piu potente da almeno 8 Kg.
Scuba is offline   Rispondi citando
Cerca nella discussione:
Ricerca avanzata
Tu non puoi inserire nuovi messaggi
Tu non puoi rispondere ai messaggi
Tu non puoi inviare files
Tu non puoi modificare i tuoi messaggi
Il codice vB č Attivato
Il codice [IMG] č Attivato
Il codice HTML č Disattivato
Trackbacks are Attivato
Pingbacks are Attivato
Refbacks are Disattivato
Quarzi alternativi ai soliti fornitori matteone Radiocomandi 0 12 marzo 07 13:11
Phoenix RC Ricambi alternativi destefanix Elimodellismo Principianti 1 04 marzo 07 23:26
Servi neri, mai provati? Baochan Aeromodellismo Principianti 32 23 febbraio 06 18:58
Per chi li ha provati tutti Baochan Simulatori 31 19 febbraio 06 13:21
Tutti gli orari sono GMT +2. Adesso sono le 12:52.
Basato su: vBulletin versione 3.6.12
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO
E' vietata la riproduzione, anche solo in parte, di contenuti e grafica. Copyright 1998/2011 - K-Bits P.I. 09395831002
