Registrazione Gallery FAQ Lista utenti Calendario Cerca I messaggi di oggi Segna forums come letti
Strumenti discussione Cerca nella discussione Visualizzazione
Vecchio 23 settembre 12, 23:40   #261 (permalink)  Top
L'avatar di RCTRIKE 1980
Data registr.: 08-06-2012
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
RCTRIKE 1980 is offline   Rispondi citando
Vecchio 28 settembre 12, 04:06   #262 (permalink)  Top
+ YouTube Video
MIA Micro-FLIGHT RC Microlights -Trikes - Ultralights.
MIA Mini True Weight-Shift Robotic Radio Controlled Microlights Ultralights Trikes
Kit Version Test Flights.
No fake links, control rods, wires or cables to make the pilot look like it is controlling the weight shift. The MIA Robo Pilot is the direct control via MIA Proprietary Geometry, CNC and custom Manufactured parts (An MIA Innovation), so control is precise, like the real thing via direct pilot control, at all times.
Designed on the same principles of our popular MIA TUFF(TM) Products so that product is not only of high performance and appeal but also of high durability. Makes use of MIA TUFF (TM) Trademark select lightweight hardware so that model is not only easy to assemble , but also air and crash worthy.
Because these MIA RC Microlight models (Trikes) approximate the real flex wing hanglider, trike, microlight, types, there is a abit of learning curve to fully understand and enjoy these models. The same thing can be said about the real ones when compared to the more typical regular airplane 3 axis type of aircraft.
There is a great amount of joy when you have a model that performs as good as these MIA products do, but you also have to have RC airplane flying hands on experience to control them.
Weight Shift Control takes a bit of practice, there are no elevator or vertical stabilizers, as on regular airplane model, to control the direction - position of the aircraft, it is all done via Power and Wing to Control Bar Dynamic Offset (weight shift, basically) control management.
A good size field for starters is a good idea as this gives one plenty room for practice.
When the model is trimmed properly it should lift easily and land into a nice glide typically done agaist the wind, the model should also fly by itself level when trimmed properly, although brisk winds will shift the position and direction of the model. This is natural and one has to make corrections via the RC transmitter stick control. This is what flying RC Controlled models is all about.
On some of the MIA Robo Trike models there are fin like shapes as part of the wheel pants and a dorsal fin stabilizer at the rear of the main mast. This is done for higher directional stability and aesthetical appeal. Real ones have all these elements for the very same reasons just explained.
Ultima modifica di RCTRIKE 1980 : 28 settembre 12 alle ore 04:11.
Vecchio 08 ottobre 12, 11:47   #263 (permalink)  Top
+ YouTube Video
Vecchio 08 ottobre 12, 12:48   #264 (permalink)  Top
+ YouTube Video
Vecchio 25 ottobre 12, 02:12   #265 (permalink)  Top
+ YouTube Video
[YOUTUBE]
Fly Away Home - RC Version - Dusk Flights - YouTube[/YOUTUBE]
Ultima modifica di RCTRIKE 1980 : 25 ottobre 12 alle ore 02:18.
Vecchio 25 ottobre 12, 02:13   #266 (permalink)  Top
Happy Holloween! Feliche Dia di Brujas! Celebratum uhm dia de Draculia e Brujildas..
+ YouTube Video
Vecchio 08 novembre 12, 22:12   #267 (permalink)  Top
L'avatar di Creative
Data registr.: 18-12-2005
Residenza: Provincia di Mantova
Invia un messaggio via MSN a Creative
Ciao, sono di nuovo tornato a sperimentare con le ali rogallo ed affini per costruirmi un mio deltaplano rc e vorrei chiedervi una cosa...
Il punto dove il carrello si aggancia alla vela sulla chiglia coincide con il punto dove è concentrato il peso della sola vela? Oppure non è detto?
Vi chiedo questo perché durante le mie prove ho dapprima lanciato la sola vela e dopo aver verficato che plani decentemente ho poi provato a zavorrarla con circa 50g di peso. Il punto è che tale peso non l'ho potuto applicare sul cg della vela ma circa 5 cm più indietro (a causa della posizione del cross-bar) ma comunque la vela volava ugualmente bene.
Mi illuminate?
Denis
Creative is offline   Rispondi citando
Vecchio 08 novembre 12, 22:23   #268 (permalink)  Top
L'avatar di AntonioF104
Data registr.: 11-04-2005
Residenza: Lauria (PZ)
hai fatto bene a fare quella prova..almeno per quanto mi riguarda... parti da lì con il CG..la prova devi farla con il peso..se la vela plana decentemente..hai già un punto da dove partire e agganciare il trike ;-)
Originalmente inviato da Creative Visualizza messaggio
Mi illuminate?
Antonio Di Giacomo
AntonioF104 is offline   Rispondi citando
Vecchio 08 novembre 12, 22:32   #269 (permalink)  Top
Originalmente inviato da AntonioF104 Visualizza messaggio
Ciao Antonio, ho giá pronto vela e carello e non mi resta che unirli e provare...
Mi preoccua il fatto che se collego la vela al trike non in corrispondenza del suo cg (della sola vela) allora essa possa tramite i leveraggi modificare l'assetto del carrello...
Spero di essermi spiegato...
Denis
Vecchio 08 novembre 12, 23:19   #270 (permalink)  Top
e io spero di aver capito.. beh guarda se tu hai provato con il peso..e la vela va bene...e il trike è bilanciato..non dovresti aver problemi, poi se usi una vela morbida, ovvero con tunnel più marcati..è più dolce e appunto morbida in beccheggio e ti permette di regolare più facilmente l'incidenza ottimale...ovvero il pendolo.
Cura anche la posizione del trike rispetto al terreno...può capitare che occorra molta incidenza per effettuare la rotazione per il decollo, ma potrebbe accadere che una volta in volo, l'ncidenza sarebbe eccessiva con conseguente "appesa" del modello. Ma niente di complicato, poi tu hai detto che vuoi usare una vela tipo rogallo con tunnel marcati vero?
Antonio Di Giacomo
Cerca nella discussione:
Ricerca avanzata
Tu non puoi inserire nuovi messaggi
Tu non puoi rispondere ai messaggi
Tu non puoi inviare files
Tu non puoi modificare i tuoi messaggi
Il codice vB è Attivato
Trackbacks are Attivato
Pingbacks are Attivato
Refbacks are Disattivato
deltaplano tropeano Aeromodellismo 3 15 aprile 09 20:21
mi aiutate a costruire 1 deltaplano a motore?!e 1overcraft ? korrado Aeromodellismo Progettazione e Costruzione 18 07 febbraio 09 17:50
Deltaplano iraciddu Discussioni Off Topic 114 03 giugno 07 03:18
Costruire un Deltaplano!! elia90aerei Modellismo 3 29 maggio 07 13:18
Tutti gli orari sono GMT +2. Adesso sono le 02:39.
Basato su: vBulletin versione 3.6.12
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO
E' vietata la riproduzione, anche solo in parte, di contenuti e grafica. Copyright 1998/2011 - K-Bits P.I. 09395831002
