Discussione: Club Blade 400-450
Vecchio 24 ottobre 11, 16:10   #12 (permalink)  Top
bandit
L'avatar di bandit
Data registr.: 18-12-2010
Blade 400-450: Parti in comune
Copio ed incollo da HF
Interchangeable parts include:
  • Fly bar weights [BLH1606]
  • Motor pinions (9T, 10T, 11T)
  • Bell Mixer Arm and Pushrod/Link Set [BLH1618]
  • Bell Mixer Pushrod/Link [BLH1619]
  • Main Grip Thrust Bearing [BLH1620]
  • Flybar Seesaw Holder Set [BLH1623]
  • Flybar, 220mm [BLH1625]
  • Flybar Paddles [BLH1628]
  • Washout Base [BLH1630]
  • Washout Control Arm and Linkage Set [BLH1631]
  • Anti-Rotation Bracket/Guide [BLH1634]
  • Control/Linkage Ball, Long [BLH1635]
  • Control/Linkage Ball, Short [BLH1636]
  • Ball Link Set [BLH1637]
  • Elevator Control Lever Set [BLH1640]
  • 5x8x2.5 Bearing elevator control arm [BLH1641]
  • 5x10x4 Bearing main shaft [BLH1642]
  • Aluminum Motor Mount Set [BLH1643]
  • Hook and Loop Battery Strap [BLH1644]
  • One-Way Bearing Shaft and Shim Set [BLH1649]
  • One-Way Bearing 6x10x12 [BLH1652]
  • Tail Drive Gear/Pulley Assembly [BLH1655]
  • Tail Drive Belt [BLH1656]
  • 2x5x2.5 Bearing: Paddle Control Frame [BLH1666]
  • Mounting Access. Screwdriver, & Wrench [BLH1674]
  • Servo Arm Set [BLH1676]
  • Brushless 420 Helicopter Motor, 3800Kv [EFLM1350H]
*B450 Canopies, blade holder, servos, gyro, ESC, and RX should also work on the Blade 400.
La bibbia dei Bladoni V6, Blade 120SR - Guida Crius Aio Pro V1.3
ATOM 500 - Blade 400 FBL STRETCHED 6s - 120SR.
bandit non รจ collegato   Rispondi citando
